<?xml version='1.0' standalone='yes'?>
<!DOCTYPE PLUGIN [
  <!ENTITY name "webgui-pr-2834">
  <!ENTITY version "2026.11.10.1727">
  <!ENTITY author "unraid">
  <!ENTITY pluginURL "https://preview.dl.unraid.net/pr-plugins/pr-2834/webgui-pr-2834.plg">
  <!ENTITY tarball "webgui-pr-2834-2026.11.10.1727.tar.gz">
  <!ENTITY sha256 "ec815c557792d4420cde149f8f88ebb5efbc543f0d8974b33e5dd24df43b57a6">
  <!ENTITY pr "2834">
  <!ENTITY commit "6b79388f7">
  <!ENTITY github "https://github.com/unraid/webgui">
<PLUGIN name="&name;-&version;"
        author="&author;"
        version="&version;"
        pluginURL="&pluginURL;"
        min="7.1.0"
        icon="wrench"
        support="&github;/pull/&pr;">
<CHANGES>
##&version;
- Test build for PR #&pr; (commit &commit;)
- Applies the PR's changes as a patch, so multiple PR test plugins can be
  installed together as long as they do not edit the same lines
- Changes are reversed when the plugin is removed
</CHANGES>
<!-- FILE sections run in the listed order -->
<!-- If this is an update: reverse the previously applied patch / restore binaries first -->
<FILE Run="/bin/bash" Method="install">
<INLINE>
<![CDATA[
echo "===================================="
echo "WebGUI PR Test Plugin Update"
echo "Version: 2026.11.10.1727"
echo ""
PLUGIN_DIR="/boot/config/plugins/webgui-pr-2834"
BACKUP_DIR="$PLUGIN_DIR/backups"
MANIFEST="$PLUGIN_DIR/installed_files.txt"
PATCH_APPLIED="$PLUGIN_DIR/applied.patch"
PAYLOAD="$PLUGIN_DIR/payload"
mkdir -p "$PLUGIN_DIR" "$BACKUP_DIR"
# Roll back THIS plugin's previous text changes by restoring the shipped
# originals, then re-applying the other still-installed PR plugins so their
# changes survive. (Deterministic: does not depend on reverse-patch context.)
if [ -f "$PLUGIN_DIR/text_files.txt" ]; then
    echo "Rolling back previous text changes..."
    while IFS= read -r sys; do
        [ -n "$sys" ] || continue
        SYS="/$sys"
        if [ -f "$PLUGIN_DIR/orig/$sys" ]; then
            mkdir -p "$(dirname "$SYS")"; cp -f "$PLUGIN_DIR/orig/$sys" "$SYS"
        else
            rm -f "$SYS"   # file was newly added by this PR
        fi
    done < "$PLUGIN_DIR/text_files.txt"
    for other in /boot/config/plugins/webgui-pr-*; do
        [ -d "$other" ] || continue
        [ "$other" == "$PLUGIN_DIR" ] && continue
        [ -f "$other/applied.patch" ] || continue
        # Non-blocking: all patches passed dry-run at install time, so failure here
        # is a rare edge case worth surfacing rather than swallowing.
        if ! patch -p1 -d / --forward --batch < "$other/applied.patch" >/dev/null 2>&1; then
            echo "⚠️  Warning: could not re-apply $(basename "$other")'s changes; reinstall it or reboot to restore them"
            logger -t webgui-pr "re-apply of $(basename "$other") patch failed during $(basename "$PLUGIN_DIR") rollback"
        fi
        # Re-applying the patch recreates any new files at 0644; restore modes.
        if [ -f "$other/modes.txt" ]; then
            while read -r mode sys; do
                [ -n "$mode" ] && [ -n "$sys" ] || continue
                [ -e "/$sys" ] && chmod "$mode" "/$sys"
            done < "$other/modes.txt"
        fi
    done
fi
rm -f "$PATCH_APPLIED"
rm -rf "$PLUGIN_DIR/orig"
rm -f "$PLUGIN_DIR/modes.txt"
: > "$PLUGIN_DIR/text_files.txt"
# Restore any previously installed binary files
if [ -f "$MANIFEST" ]; then
    echo "Restoring binary files from previous version..."
    while IFS='|' read -r system_file backup_file; do
        [ -n "$system_file" ] || continue
        if [ "$backup_file" == "NEW" ]; then
            [ -e "$system_file" ] && { echo "Removing PR file: $system_file"; rm -f "$system_file"; }
        elif [ -f "$backup_file" ]; then
            echo "Restoring original: $system_file"
            cp -fp "$backup_file" "$system_file"
        fi
    done < "$MANIFEST"
fi
: > "$MANIFEST"
rm -rf "$PAYLOAD"
echo "Ready for fresh install of PR files."
</INLINE>
</FILE>
<!-- Create plugin directories -->
<INLINE>
<![CDATA[
echo "WebGUI PR Test Plugin Installation"
echo "PR: #2834"
echo "Commit: 6b79388f7"
echo ""
mkdir -p /boot/config/plugins/webgui-pr-2834/backups
echo "Created plugin directories"
</INLINE>
</FILE>
<!-- Download tarball from GitHub/R2 -->
<FILE Name="/boot/config/plugins/webgui-pr-2834/webgui-pr-2834-2026.11.10.1727.tar.gz">
<URL>https://preview.dl.unraid.net/pr-plugins/pr-2834/webgui-pr-2834-2026.11.10.1727.tar.gz</URL>
<SHA256>&sha256;</SHA256>
</FILE>
<!-- Apply patch + install binaries -->
<INLINE>
<![CDATA[
TARBALL="$PLUGIN_DIR/webgui-pr-2834-2026.11.10.1727.tar.gz"
echo "Extracting payload..."
rm -rf "$PAYLOAD"
mkdir -p "$PAYLOAD"
tar -xzf "$TARBALL" -C "$PAYLOAD"
: > "$MANIFEST"
# ---- Text changes: apply unified diff -------------------------------------
if [ -s "$PAYLOAD/pr.patch" ]; then
    echo "Checking patch applies cleanly..."
    if ! patch -p1 -d / --dry-run --forward --batch < "$PAYLOAD/pr.patch" > /tmp/pr_patch_check.txt 2>&1; then
        echo ""
        echo "❌ Install aborted: this PR's changes do not apply cleanly."
        echo "   Another installed PR plugin likely edits the same lines."
        echo "------------------------------------------------------------"
        grep -Ei 'FAILED|can.t find file|hunk' /tmp/pr_patch_check.txt || cat /tmp/pr_patch_check.txt
        echo "Remove the conflicting webgui-pr-* plugin and try again."
        rm -f /tmp/pr_patch_check.txt
        exit 1
    fi
    echo "Applying patch..."
    patch -p1 -d / --forward --batch < "$PAYLOAD/pr.patch"
    cp -f "$PAYLOAD/pr.patch" "$PATCH_APPLIED"
    # Persist the originals + file list so removal can rebuild deterministically
    [ -d "$PAYLOAD/orig" ] && cp -a "$PAYLOAD/orig" "$PLUGIN_DIR/orig"
    [ -f "$PAYLOAD/text_files.txt" ] && cp -f "$PAYLOAD/text_files.txt" "$PLUGIN_DIR/text_files.txt"
    echo "✅ Patch applied"
fi
# ---- Binary changes: whole-file replace (cannot be merged) -----------------
if [ -s "$PAYLOAD/binary_files.txt" ]; then
    # Guard: a binary may only be managed by one PR plugin at a time
            if [ -f "$other/installed_files.txt" ] && grep -q "^/$sys|" "$other/installed_files.txt"; then
                echo "❌ Install aborted: binary /$sys is already managed by $(basename "$other")."
                echo "   Remove that plugin first: plugin remove $(basename "$other").plg"
                exit 1
            fi
        done
    done < "$PAYLOAD/binary_files.txt"
        SYS="/$sys"
        SRC="$PAYLOAD/binary/$sys"
        BK="$BACKUP_DIR/$(echo "$sys" | tr '/' '_')"
        if [ -f "$SYS" ] && [ ! -f "$BK" ]; then cp -p "$SYS" "$BK"; fi
        if [ -f "$BK" ]; then echo "$SYS|$BK" >> "$MANIFEST"; else echo "$SYS|NEW" >> "$MANIFEST"; fi
        cp -f "$SRC" "$SYS"
        echo "Installed binary: $SYS"
fi
# ---- Restore file modes ----------------------------------------------------
# Unified diffs carry no permission bits, so patched/new text files land 0644
# and lose any exec bit. Re-apply the modes recorded at build time. Persist
# modes.txt so rolling back another PR plugin can restore them too.
if [ -f "$PAYLOAD/modes.txt" ]; then
    cp -f "$PAYLOAD/modes.txt" "$PLUGIN_DIR/modes.txt"
    done < "$PAYLOAD/modes.txt"
    echo "✅ File modes restored"
fi
# ---- Restart patched nchan publishers --------------------------------------
# nchan publishers (scripts under .../nchan/) are long-running loops. The running
# process keeps executing the OLD script after we patch it on disk - and a browser
# reload won't fix it, because DefaultPageLayout only (re)launches a publisher that
# is NOT already running. So a patched publisher would keep streaming stale output
# until every tab closes and monitor_nchan idle-reaps it. Kill the ones this PR
# touched; DefaultPageLayout respawns them with the new code on the next page load.
# Safe: monitor_nchan kills these routinely, and subscribers stay connected and
# resume from the respawned publisher (matches the ResetTZ.php reload pattern).
if [ -s "$PAYLOAD/text_files.txt" ]; then
    grep -aoE '/nchan/[^/]+$' "$PAYLOAD/text_files.txt" 2>/dev/null | sed 's#^/##' | sort -u | while IFS= read -r rel; do
        [ -n "$rel" ] || continue
        if pkill -f "$rel" 2>/dev/null; then echo "Restarted nchan publisher: $rel"; fi
    done
fi
# ---- Reactivate overlaid system daemons ------------------------------------
# The patch is applied late (on install, and at boot AFTER rc.M has already
# started these daemons with the stock config), so config we just overlaid does
# not take effect until the matching daemon is bounced — a plain reboot alone
# does not help because the plugin re-applies after rc.M each time. Restart the
# affected daemons here (after modes are restored, so their rc scripts are
# executable). Keep this to daemons that are safe to bounce live. Paths in
# text_files.txt are the packaged layout (etc/rc.d/* maps to usr/local/etc/rc.d/*).
    # elogind owns the physical power key unless a drop-in tells it to ignore it;
    # it only reads logind.conf.d/ at startup, so reload it when that changes.
    if grep -qE 'etc/elogind/|rc\.d/rc\.elogind$' "$PAYLOAD/text_files.txt" && [ -x /etc/rc.d/rc.elogind ]; then
        echo "Reloading elogind (session/power-key policy changed)..."
        /etc/rc.d/rc.elogind restart >/dev/null 2>&1 || true
    fi
    # rc.acpid installs Unraid's ACPI handler over the stock one at (re)start.
    if grep -qE 'etc/acpi/|rc\.d/rc\.acpid$' "$PAYLOAD/text_files.txt" && [ -x /etc/rc.d/rc.acpid ]; then
        echo "Restarting acpid (ACPI handler changed)..."
        /etc/rc.d/rc.acpid restart >/dev/null 2>&1 || true
    fi
fi
echo ""
echo "✅ Installation complete for PR #2834"
echo "⚠️  This is a TEST plugin — remove it before applying production updates"
echo "⚠️  A reboot may be required for some changes to take effect"
</INLINE>
</FILE>
<!-- Add a banner to warn user this plugin is installed -->
<FILE Name="/usr/local/emhttp/plugins/webgui-pr-2834/Banner-2834.page">
<INLINE>
<![CDATA[
Menu='Buttons'
Link='nav-user'
<script>
  $(function() {
    // Check for updates (non-dismissible)
    caPluginUpdateCheck("webgui-pr-2834.plg", {noDismiss: true},function(result){
      try {
        let json = JSON.parse(result);
        if ( ! json.version ) {
          addBannerWarning("Note: webgui-pr-2834 has either been merged or removed");
      } catch(e) {}
    // Create banner with uninstall link (nondismissible)
    let bannerMessage = "Modified GUI installed via <b>webgui-pr-2834</b> plugin. " +
                       "<a onclick='uninstallPRPlugin()' style='cursor: pointer; text-decoration: underline;'>Click here to uninstall</a>";
    // true = warning style, true = non-dismissible
    addBannerWarning(bannerMessage, true, true);
    // Define uninstall function
    window.uninstallPRPlugin = function() {
      swal({
        title: "Uninstall PR Test Plugin?",
        text: "This will reverse all of this PR's changes and remove the test plugin.",
        type: "warning",
        showCancelButton: true,
        confirmButtonText: "Yes, uninstall",
        cancelButtonText: "Cancel",
        closeOnConfirm: false,
        showLoaderOnConfirm: true
      }, function(isConfirm) {
        if (isConfirm) {
          openPlugin("plugin remove webgui-pr-2834.plg", "Removing PR Test Plugin", "", "refresh");
</script>
</INLINE>
</FILE>
<!-- Removal script -->
<FILE Run="/bin/bash" Method="remove">
<INLINE>
<![CDATA[
echo "WebGUI PR Test Plugin Removal"
echo ""
# Restore this plugin's text files to their shipped originals, then re-apply the
# other still-installed PR plugins so their (non-overlapping) changes survive.
    echo "Restoring text files..."
        SYS="/$sys"
        else
        fi
        fi
    done
    # Restart any nchan publishers this PR patched so the live process drops the
    # patched code and respawns from the restored original on the next page load
    # (long-running publishers don't pick up the on-disk change until killed).
    grep -aoE '/nchan/[^/]+$' "$PLUGIN_DIR/text_files.txt" 2>/dev/null | sed 's#^/##' | sort -u | while IFS= read -r rel; do
    done
    echo "✅ Text changes restored"
fi
# Restore binary files
    echo "Restoring binary files..."
            [ -e "$system_file" ] && { echo "Removing new file: $system_file"; rm -f "$system_file"; }
            echo "Restoring: $system_file"
        else
            echo "⚠️  Missing backup for: $system_file"
        fi
    done < "$MANIFEST"
fi
echo "Cleaning up plugin files..."
rm -rf "/usr/local/emhttp/plugins/webgui-pr-2834"
rm -rf "$PLUGIN_DIR"
echo ""
echo "✅ Plugin removed successfully"
echo "⚠️  A reboot may be required to fully clear all changes"
</INLINE>
</FILE>
</PLUGIN>
